kyocera ecosys m2035dn
  • oxus investment
    [Error Code] kyocera ecosys m2035dn
    my ecosys m2035dn is displaying error cf010
  • GeneOR95
    • Feb 2018
    • 161
    Re: kyocera ecosys m2035dn
    F010 Control PWB
    Checksum error
    Control PWB Unplug the power cord from the wall outlet, and wait five seconds. then turn on the power switch.
    If not corrected, replace the control PWB and check operation.
    • a.d. dhima
      I have the same error display in my ecosys 2035dn, tried several times to swith it on and off, and same situation. what should I do?
        • 23008
        All CFxxx codes fit in two categories:
        1) a firmware or communication error between boards
        2) a print data error
        If you disconnect the network cable and can successfully boot up and copy, it's probably a print data error.
        If you disconnect the network cable and it still does not boot without error, it's probably a firmware error or communication error.
          • 8144
          Shut machine down unplug the network cable & delete any waiting jobs update the firmware to latest version & power back on.
