Exactly what type of compact flash do new kyoceras use ? SDHD SD ? It's sure not the old compact flash card
Compact Flash
Re: Compact Flash
What model? You have to go back to the Falcon series or Stratos series or Voyager series to flash firmware with a compact flash card. I believe the Saturn would still flash with compact flash card but only from a special CF port on the main PWB. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
