We have a 5551 ci with the df-790 finisher that keeps getting J6000 ,J6001 jams. Of course it never does it when we go there. We have checked all of the sencors and they all check ok .
Taskalpha 5551ci j6000,6001 codes
Re: Taskalpha 5551ci j6000,6001 codes
wow the 2 codes are for 2 different finishers. anyway I would try another fuser 1st.,and id that don't fix it replace the exit assm. -
You do not indicate if it occurs with a certain paper size or from a particular drawer? The code indicates that the machine is seeing the paper arrive at the finisher before it exited from the machine. Have you asked the customer what they are doing when the jam code occurs? Had one quite awhile back on anther model, where someone [of course they did not touch anything] had set the MPT to metric while the rest of the machine was set for inch. Created some weird jam codes whenever they used the MPT which they never ever used! When the jam code appears are they copying or printing? You could have a similar situation with one user that has selected metric size in their print driver. It is obvious that the machine is looking for the timing on one paper size and detecting the sensors for a different size. Hope this helps a little.Comment
Current full size models (not tabletop) can select more sizes than you can name in ANSI, ISO, JIS, and Custom paper sizes, individually to each tray.
Now if it was mis-programmed ... A3 in an Auto (inch) tray (reading LDG on the screen), there you might have something. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Santander mentioned the jam code was paper arriving at the finisher before it exits the machine. I have seen this issue before but don't remember the exact jam code.
On mine the low voltage power supply (LVPS) had been changed shortly before the issue appeared. The small 2 pin connector on the LVPS had been overlooked. This connector is the signal for the machine to exit sleep mode. The machine was OK for walk up copying because the user had to wake the machine first. If they sent a print job the copier would jam on the first sheet because the machine didn't get the signal to exit sleep mode.
Set the energy save and sleep mode for 1 minute and let the machine go into sleep mode. If the jam happens when printing from sleep mode (not copying) then check the small 2 pin connector at the top of the low voltage power supply.Comment
If you are getting a 6110 code, look at the gear that drives the intake rollers to the finisher. We have had a few of these finishers that have had a cracked gear that will randomly slip creating a jam code. Even if the finisher operates normally, if the gear is cracked it will create a faint thumping sound [best way I can describe it] when the finisher is running. Usually the crack is so small that it is hard to detect unless you remove the gear from the shaft and stress it manually.Comment
