TA-dcc6626L mfp white horizontal lines
  • batabusiness
    • Sep 2015
    • 12
    hello , this triumph adler A4 color mfp , give white thin lines in all colors every 10 cm , or random , i refreshed the drums , cleaned laser glass, drum ,developer , and transfer belt look good , so what is the cause , thanks
    Re: TA-dcc6626L mfp white horizontal lines
    ok on a DIGITAL unit WHAT produces white lines? think
    • batabusiness
      • Sep 2015
      • 12
      i think its the laser unit, but i made laser glass cleaning program , and i cleaned it manually too , but same problem , drum ,transfer unit , and developer seem good , this problem i have in 3 printers same model.
        • 22943
        Do you have an image sample that indicated feed direction? =^..^=
