Kyocera Taskalfa 3500i Print too light
  • kashif
    • Apr 2013
    • 45
    #16
    Re: Kyocera Taskalfa 3500i Print too light
    What about internal print? if internal print is good then i think you go for optics otherwise sound like transfer
    • JPazy
      • Jul 2019
      • 30
      #17
      I have seen transfer belt bushing on rear side fall out of the frame of the TX unit cause poor transfer. Is toner genuine Kyocera toner? Generic toner will cause poor fill.
        • 23008
        #18
        Definitely transfer. Start with reseating all the connectors on the relay PWB. Maybe the actual transfer roller inside the belt is dislodged. It would be nice if you had a spare transfer assembly to swap in. =^..^=
        • pgrom
          • Apr 2016
          • 10
          #19
          But transfer looks good
          • darry1322
            • Oct 2010
            • 817
            #20
            You say the image is good on the drum, but you have light print on the paper. The transfer does not look good.
            The transfer assembly may look good, but the appearance of the assembly doesn't matter. Something isn't right.
            All this assumes good image on the drum. It's hard to tell from your pictures if the toner coverage on the drum is really good or not.
            • pgrom
              • Apr 2016
              • 10
              #21
              • darry1322
                • Oct 2010
                • 817
                #22
                [ATTACH=CONFIG]43232[/ATTACH]
                Yep, that's a transfer unit. Good or bad? Can't always tell by looking at it. If you have a known good one (from a working machine) try swapping it out. Next step would be checking electrical connections.
                • copiertec
                  • Jan 2016
                  • 2206
                  #23
                  Are you using OEM toner? Or is it generic?
                  • tsbservice
                    Field tech
                    • 8016
                    #24
                    ... Where the prints light prior to drum and developer change?
                    Agreed with others, but OP seems didn't answer most important question were light prints BEFORE parts change? It is either tech induced problem or bad transfer/HV. If problem was present before I wouldn't start putting expensive consumables in the machine without considering all possibilities as at some point customers may be pissed off with paying and not getting any better.
                    • pgrom
                      • Apr 2016
                      • 10
                      #25
                      Ech
                      BEFORE!!!
                      AFTER change drum and dev!!!
                      I have already written that after the exchange of parts nothing has changed
                      • copiertec
                        • Jan 2016
                        • 2206
                        #26
                        I have a problem with Kyocera Taskalfa, it prints to light. I replaced the developer, drum, the contacts are clean , the machine not covered with toner. The image on the drum is good but the printout is too light. The copier has printed 100k
                        [ATTACH=CONFIG]43221[/ATTACH]
                        Please Help
                        Is the toner cartridge OEM or generic? If it is generic that could also be causing your issue.
                        • pgrom
                          • Apr 2016
                          • 10
                          #27
                          Toner Kyocera Original
                          • JR2ALTA
                            • Feb 2010
                            • 2033
                            #28
                            You either have a transfer or bias problem
                            • copiertec
                              • Jan 2016
                              • 2206
                              #29
                              Is the laser unit glass clean? Located above the drum unit. If it is, then we have covered mostly all the basis. I would make sure all the factory settings are initialized u021, if that does not resolve your issue, you are looking at a voltage issue.
                              • Geo
                                • 662
                                #30
                                Did you check the transfer assy spring contact on the copier side? Easy to miss.
