Automate printjob from folder with ftp on Kyocera
  • Froota
    Field service tech.
    • 128
    Hi guys,
    I'm struggling with something I never used before. Customer wants to drop a pdf to a specific folder, and this document should be printed automatically on a Kyocera device.
    Apparently this can be fixed with FTP, allthough I've never set it up, for example on a Taskalfa 2553ci.
    FTP server (receive) is set to on in the protocol menu (command center), and I was abble to connect to the ftp with a command prompt (ftp://ipdevice), also through filezilla for example.
    question 1:
    I can see LP1-2-3 and 4, four folder locations, but I don't exactly know what this means and where I can find this location on the printer.
    question 2:
    I've tried to map one of the four LP folders so we can drop documents in it, but this isn't possible i guess?
    Question 3:
    Do i need a script to load documents to this ftp location, if yes, can someone help me with this?
    Otherwise I can't find any service or hands-on manual/procedure to set those things up........
    Thx in advance guys,
    Froota
    • 27451
    Re: Automate printjob from folder with ftp on Kyocera
    Nice one, there maybe a hypass app or some kind of workflow you can setup for it. I saw Toshiba has it. Put a call into the Hotline
    If you don't have support as a tech call them as the customer
    There are some 3rd party software that can also do it.
    • Ropariva
      • 591
      You can just browse to the LP ports. Just type in \\(IP-Address) and you will see the LP ports. Drop your PDF into any one of these.
      • Froota
        Field service tech.
        • 128
        Yes, I could browse it before, but for what stands LP? Logical printer? if so, what benefit does the 4 maps gives to me?
        I added one of the 4 lp folders as a networkfolder, and now i can drop and automatically print, so this works already.
