2552ci
  • mansart
    • 852
    2552ci
    Is there a built in method of wiping HDD on one of these?
    I have a lease return, cust wants HDD wiped. I'm a "Sharp" guy, I know I can wipe drive but are there any files needed to reload to make machine function?
    Thank you.
    • 2621
    Re: 2552ci
    U24 hard drive format should do the job and you will never lose valuable firmware files.
    U002 factory defaults
    Copytechnet search tool v0.8 Final
    • KYO_OEM
      • Aug 2011
      • 636
      Re: 2552ci
      1.
      use data sanitization from systemmenue."System/ network-->(2500,2500)--> Enter data security--> Data Sanitization--> run immediatately ( it takes a little bit time, but all data would removed and you`ll get report about this.
      2.
      Run complete FW upgrade
      finished if no special applications needed
