CS3550ci Enabling " Job Accounting " broke " Send to Email "
  • AColbe01
    • Dec 2013
    • 15
    Anyone have a solution for why enabling "Job Accounting" makes the email SMTP/POP3 values invalid
    with regards to "Send to Email"?
    KNOW!!! the settings work when "Job Accounting" disabled. Sends scan to emails like a champ with copier email account info.
    KNOW!!! Individual users are setup as Administrators with NO "Restrict Usage" .... including "Send Restriction:"
    Only 7 users, non-can email w job accounting on.
    What am I doing wrong? Failed to configure? Feel like it's something simple!
    TIA
    • 27450
    Re: CS3550ci Enabling " Job Accounting " broke " Send to Email "
    User name does not match sender
    • Blizzoo
      • Aug 2013
      • 588
      Job Accounting is activating a security option that to me looks like is trying to authenticate the logged in user with the smtp you posted instead of using the one set into device. Isn't there a setting to lock the sender address somewhere? Just throwing and idea...
        • 27450
        Normally its not an issue check settings in Job accounting
        Something on that should not be.
          • 27450
          Authentication should be off
          Job accounting on
            • 14755
            [ATTACH=CONFIG]47623[/ATTACH][ATTACH=CONFIG]47624[/ATTACH][ATTACH=CONFIG]47625[/ATTACH][ATTACH=CONFIG]47626[/ATTACH]
            TIA
            What message are you getting on the screen when you try to send an email?
              • 14755
              Job accounting on
              Agreed. Using both is pointless.
                • 14755
                Actually, I don't think job accounting has anything to so with smtp - sending an email. I just activated job accounting and authorization and I'm able to send an email just fine. You may, however, want to check your send security settings.
                PS - If all else fails reset the machine back to factory default and start over.
                • AColbe01
                  • Dec 2013
                  • 15
                  [ATTACH=CONFIG]47629[/ATTACH]
                  Thought about that, talked w Kyocera tech support and there have been about 15 firmware updates since production (this one is @ production)
                  • AColbe01
                    • Dec 2013
                    • 15
                    the first pic is the panel showing issue with smtp /pop3
                    • AColbe01
                      • Dec 2013
                      • 15
                      Thank you for posting the pic! I haven't seen THAT! screen! possibly from an update to one of the firmwares?
                        • 14755
                        I can't read it, image is too small.
                          • 14755
                          You're working with the 0 series. I'm working with the 1 series but I think the setting are the same. From the homescreen go to Security Settings and then Send Security
                          Sorry, I forgot the Homescreen is different on the 0 series. You'll have to look around in the settings for it. I don't have a 3550 in the shop.
