Kyocera M6235cidn color registration problem
Tags: None
I had something like this on that model. Initially found the transfer unit was skipping, and that resolved a noise, but was still showing registration shift. After that, tech support told me to replace the main board. It was chargeable so the customer(inter-territorial) upgraded. -
How many times consecutively did you align it. I've had it take 15 times or more to get into range. =^..^=If you'd like a serious answer to your request:
Good morning martinkrys,
One of my co-workers ran into that. He contacted the Kyocera Technical Support hotline and they provided a reset file called...
Reset File For ColorShift(SN_RC1xxxxxxx).capt I personally have not tried this yet, but it worked for him. This system won't allow me to upload it because of the file type ".capt". I can email it to you if want. Send me a message to... cbijamest@gmail.com Attached are before and after samples that my co-worker sent to me last September.Comment
I had something like this on that model. Initially found the transfer unit was skipping, and that resolved a noise, but was still showing registration shift. After that, tech support told me to replace the main board. It was chargeable so the customer(inter-territorial) upgraded.Comment
​Comment
You were right - I did 15 times manual color registration with extreme values and this resolved a problem. Btw, there is no reset FW or reset file for this type of machineComment
