TA 2500 KYOCERA 2551 color shift
  • enricocopyline
    • Jun 2018
    • 122
    good morning, I have a ta 2500 (kyocera 2551) that prints with a color offset of 0.5cm, how can I solve the problem?
    as attached​
    thanks
  • Larhal
    • 571
    as attached
    thanks
    What have you done to trouble shoot this problem?
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
    • enricocopyline
      • Jun 2018
      • 122
      I did the 410 adjustment but it didn't solve the problem
      • Larhal
        • 571
        Did you move or replace any of the Drum Units? How about the Laser have you moved or replaced the unit. Seems that your black drum may not be installed correctly. Have you done anything with the ITB?
        Larhal
        • Samanator
          • Sep 2017
          • 579
          By all means check what Larhal has pointed out.
          But, have you tried U468?
          First Auto and if that doesn't do it, do (ugh) Manual. Manual is tedious and you may have to do it a couple of times.
          • enricocopyline
            • Jun 2018
            • 122
            no I didn't touch anything other than black the other colors are off. the black is printed in the right position....
            • Larhal
              • 571
              Ok what did you originally do with the Black drum unit? You say the other colours are off but you disturbed the Black drum unit. That would indicate that the colours are OK but the black is off. why did you remove the black drum unit, what was the problem?
              Try removing and reseating the Black drum unit.
              Lets keep this simple and investigate what you have done and the reason for it. Maybe this will lead us to resolving the problem.
              Larhal
              • Lunatech
                • Oct 2012
                • 207
                Any error codes in the event log? 7620?
                • KYO_OEM
                  • Aug 2011
                  • 715
                  Run U468 / “Initialize“ / “Execute“ and press [OK] key
                  Check if all values of [Auto] and [Manual] > ”0”
                  If values = “0“>>enter U001 and press [OK] key / if other values > repeat U468
                  No other changings, no copies/ no printouts during this procedure!!
                  Finally run System menu > adjustment/maintenance > 2. page >
                  1. Calibration
                  2. Color Registration/ manual/detail
