KYOCERA 3060
  • MOHRAY
    • Sep 2021
    • 3
    KYOCERA 3060
    My Kyocera KM-3060 has so many annoying dots when photocopying or printing. i have attached a test page. Help me fix this.
  • dalewb74
    • Feb 2018
    • 1153
    Re: KYOCERA 3060
    the fix for this is due to the age of the copier buy a new one.... put this one in a museum.
      • 23008
      Re: KYOCERA 3060
      Something is arcing to the drum. A drum and developing unit will fix this ... if you can find them. =^..^=
      • copier tech
        • 8144
        Re: KYOCERA 3060
        As others have said old model but caused by the drum/dev arching. You could try removing the drum/dev & vacuuming up any stray toner/paper dust.
          • 37490
          Re: KYOCERA 3060
          Since the spot pattern is not repeated at an interval equal to the circumference of the drum, the drum might still be good. Most likely the developer is either contaminated or not genuine Kyo. Have the developer replaced before it destroys the drum.
          • MOHRAY
            • Sep 2021
            • 3
            Re: KYOCERA 3060
            i can find them
            • MOHRAY
              • Sep 2021
              • 3
              Re: KYOCERA 3060
              i will try and change the developing unit because i have tried the drum unit with a similar photocopier and it does print those spot patterns.
              • Drivee
                • Nov 2020
                • 322
                Re: KYOCERA 3060
                Hi
                I look your print sample. You don't have problem with OPC or DEV. The problem is gap between DEV roller and OPC. Something did not sit well. The magnetic roller is too close to OPC. Maybe you have toner build up on dev section and OPC will pick that toner and make that on print page. Most likely. You can start from there.
                • JeffMills
                  • 22
                  Re: KYOCERA 3060
                  Is this the status page of this copier?
                  if so once you get problem fixed charge grid ? etc.
                  looks like time to intialize hdd and machine .
                  265 /to a --2
                  252/ inch
