Letterhead configuration PA5500x MA5500ifx NOTARY office
  • masky
    • Aug 2010
    • 51
    Hello, I have a PA5500x and a MA5500ifx machines installed in a notary's office. This type of client needs to print notarial deeds on letterhead. The problem is that it is a paper numbered by law and the printing must be done consecutively. The problem is if the printouts are odd since the double printing Kyocera always starts printing first on the "B" side or second side. When printing deeds, if the total number of pages in the document is an odd number, the last page does not print in the correct place. This problem in HP machines is solved with the option: letterhead alteration, but in Kyocera I do not know the solution. Thanks
  • Slammers
    • Feb 2019
    • 136
    It sounds like you need to change the "Special Paper Action" setting in the web interface.
    Log in as Admin -> Device Settings -> Paper/Feed/Output -> Other Settings Heading and change "Special Paper Action from "Speed Priority to "Adjust Print Direction".
    You may need to flip headed paper in the tray after this adjustment.
    Screen shot belolw shows the DEAFULT which is "Speed Priority"
    • masky
      • Aug 2010
      • 51
      Dear friend, this is exactly what I was looking for and your post has been incredibly helpful. Thank you.
