M5526cdw scanning half black from document feeder
  • kuby
    • Oct 2007
    • 1396
    Have a M5526cdw scanning half black pages from the document feeder, the copies from the glass or scans from the glass are fine. Have not run into this before. Anyone seen this before? Replace the whole DF, boards, etc?
    Customer said they cleaned the scan and reading glass and they are OK.
  • ATM
    • Apr 2025
    • 32
    I've seen a similar problem before, but it was with the Ecosys M2040dn. There was a problem with (don't know how to name this part in english - sorry) foil under the glass, which peeled off a little and prevented the CIS sensor from moving correctly into starting position.
    Is this sample a scan or a copy? Single-sided or double-sided?
    • KYO_OEM
      • Aug 2011
      • 710
      Have had the same as ATM,
      white reference plate peeled of from glass platen peels of and scanner can't run in correct Position.
      • kuby
        • Oct 2007
        • 1396
        Under the platen glass or in the document feeder? I am guessing under the platen glass.
        • ATM
          • Apr 2025
          • 32
          Take a look under the area marked in red.
          • kuby
            • Oct 2007
            • 1396
            Thanks, I will look at that Monday. Customer is a hour away.
            • kuby
              • Oct 2007
              • 1396
              Wasn't the white reference plate but the seal next to it. Stuck it back and secured and OK now. Thanks
