Kyocera fs-c8525 When turned on, all the motors and fans start spinning. After that, Error 6930 appears
Kyocera fs-c8525 Ошибка 6930
Tags: None
- Code: 6930
- Description:IH related cooling fan motor error
The alarm signal was detected for 5 seconds continuously during operation. - Causes : Defective connector cable or poor contact in the connector.
- Remedy : Defective connector cable or poor contact in the connector. Reinsert the connector. Also check for continuity within the connector cable. If none, replace the cable. Container / IH coil fan motor and relay connector * and engine PWB(YC21) *:Insertion of the above-mentioned relay connector is checked. IH fan motor and engine PWB(YC24)
Defective cooling fan motor. Replace the container / IH coil fan motor or the IH fan motor.
Defective PWB. Replace the engine PWB and check for correct operation.
As I already wrote: All fans are running (spinning). But I measured the voltage while turning on the MFP on the fuser, the multimeter shows "0".Comment
If you're talking about these fans, they also spin when you turn on the device.You do not have permission to view this gallery.
This gallery has 1 photos.Comment
