4500i, cust. wants 2 fax lines ? addit. card ?
  • CCS
    • 266
    One of my customers wants to have 2 different fax lines coming into their 4500i copier, it currently has the regular fax system V card, is there an additional fax add-on card for dual fax capability ?, as they saw an online brochure stating something like this may be available ???
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1863
    Re: 4500i, cust. wants 2 fax lines ? addit. card ?
    You should be able to add an additional fax in the second slot. It would be a fax V as well.
    I haven't done it on this model, but have on a KM-5050.
    I believe you set which line is for sending if I remember correctly.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • progoffice
      • Nov 2008
      • 334
      Yes. You can have two fax cards installed on this machine. I believe only one card (Option 1) can be used to send faxes, but they can both receive. With this set up, the machine can be sending and also receiving a fax simultaneously.
        • 29562
        Kyocera supports two fax cards
          • 22968
          This is correct. You can choose which fax card sends ... but only one card can send. I had a couple of customers go in together to buy an MFP, and wanted separated phone lines and phone bills. That just doesn't work. =^..^=
          • CCS
            • 266
            Thanks guys, I'll stick another fax card in then
