Kyocera 3500i
  • davez@copysystemspa.com
    • Feb 2018
    • 23
    Kyocera 3500i
    I just took in a Kyocera Takalfa 3500i machine that was connected to a coin box as I am getting an "insert coins" window upon start up. I need to get into the service modes to return it to the standard office modes. From memory, and it's been awhile, I thought I had to input 1,0,8,7 to get into the modes but that isn't working. Can someone please assist me?
    • 22694
    Re: Kyocera 3500i
    10871087 will get you into service mode ... if it hasn't been changed. And U206 will take you to vendor mode. =^..^=
    • oldschool
      • Mar 2007
      • 245
      Re: Kyocera 3500i
      It can also be set in U204. It has been reported to me that newer Kyocera models have a coin vendor option in U204 as well as a key counter option. I believe it just changes the message to "Insert Coin" but I have very little information on the option or how it works. I'd guess it's in U204 because if U206 is set, you will likely receive a 9010 error on boot if the coin box is not connected.
      Jamex Tech Support: Saving the world one phone call at a time.
      • JR2ALTA
        • Feb 2010
        • 2016
        Re: Kyocera 3500i
        One release of Kyocera's had a oddball way of getting into Maintenance Mode. I believe you had to be in System Menu or maybe hit the Interrupt button before 1087.
        • Samanator
          • Sep 2017
          • 561
          Re: Kyocera 3500i
          not on the 3500i. Just good old 10871087.
