4002i - large void area
    • 15238
    I delivered the machine on Saturday...all was working. I went back today and and almost half of the page is void of toner coverage. It's the same exact pattern no matter how many pages I print.
    Initially I thought it could be a moisture problem. I changed paper and did a drum refresh a few times with no success.
    It looks like a DV problem??
    Thoughts?
    • 15238
    Re: 4002i - large void area
    Sorry, forgot to add examples. My bad.
    doc00013920220606163432.pdf
    • Santander
      • May 2009
      • 768
      Is the secondary transfer roller making full contact with the drum? There is a spring on each side to press the transfer roller against the drum, if one is missing the roller only contacts part of the drum and creates a light or no image on that side.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1823
        Looks like the gray push arm isn't latching on the DV unit. If it's not, put a plastic screw in it to hold it, or try removing the spring.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
          • 22753
          I like Tony's response. I've also seen that push rod pop out of it's holders, producing a similar effect.
          Did you get a solution yet? =^..^=
            • 15238
            This was a new sell so I just replaced with a like machine and brought the problem machine back to the shop. I'm gonna try to take a look at it today. I don't have much experience on this model. I'm curious what the problem is. It was working fine when I first delivered it. I'll update after I take a look.
            • sparkycivic
              • Apr 2017
              • 348
              The early-production DV-8550 developers had the habit of breaking the tiny plastic tang part of the engagement button giving partial to mostly void pages.
              Farmer-fix is to jam a screw into the side of the button so it stays completely engaged.
              Proper fix is to replace the developer unit.
              I can't recommend removing the spring from the cable tension part because then we might scratch the drum surface while installing/removing having become unable to disengage the dv roller from the drum surface.
                • 15238
                First things first... thanks to everyone that assisted in helping fix this machine. It is truly appreciated.
                The fix was the little button on the DV unit. I used a screw to hold the button in and viola, full toner coverage.
                IMHO, this is a terrible design. What engineer come up with this? Nonetheless, now I know how to deal with it.
                See test prints below:
                sample set.pdf
                  • 22753
                  Congratulations on your success. =^..^=
