Km-2050 fax problem.
  • cmpelser
    • Jan 2008
    • 173
    Transfering NW-fax data. What dose this mean? It happens randomly then goes away. Can't send or recieve faxes.
  • charly
    • 65
    the fax or report forward to pc ,review the configuration with kyocera adress editor
    • cmpelser
      • Jan 2008
      • 173
      Where do I find the kyocera adress editor???
      Is it in the command centre?
      I was thinking it had somthing to do with firmware...
      Thanks.
      • charly
        • 65
        in the driver disk fax or KYOCERA MITA | Service / Support | Download Center
        • cmpelser
          • Jan 2008
          • 173
          I don't know about this topic at all...
          Is anyone willing to explain the basics of this to me?
          does the machine need to have a scan option installed or not, why?
          thanks guys!
          • vikingmita
            • Nov 2008
            • 163
            network fax needs scanner, if that's what you're asking. have you turned off network fax?
