taskalfa 3501i
  • Gab
    • Aug 2015
    • 663
    taskalfa 3501i
    When make a copy the first page is ok the second few dark lines , third page has a lot of wider dark lines.
    The lines are not look from drum .Charge roller is new ,Performed dev initialazation, drum refresh ,calibration with no result. Any idea?
    • 22963
    Re: taskalfa 3501i
    samples?
    • Gab
      • Aug 2015
      • 663
      Re: taskalfa 3501i
      Today i had the same problem to an other machine.
      I have noticed that in both machines the toner is almost empty . HAs the problem something to do with this?
        • 22963
        Re: taskalfa 3501i
        hmmm, do you have any samples?
        • Gab
          • Aug 2015
          • 663
          Re: taskalfa 3501i
          Im remembered that 2 months ago i have had the same problem with this exact machine. I replaced developer unit with an other from an other machine and it worked till now
          In the attached files samples of 1st 2nd and 3nd page
          • copydocinc
            • Mar 2015
            • 263
            Re: taskalfa 3501i
            It looks like the same problem I have noticed when using compatible toners.
            You can go to sim 147 and change the mode setting to 0 instead of 1
            This setting will use less toner
            or you can change to OEM toners, but maybe you will still need to change mode setting to 0 if the developer
            unit is contaminated enough from the compatible toner previously
