KMC2525E address book missing
  • Colonicaminota
    • 12
    i am experiencing a issue with the KMC2525E where no address book is available within the web interface. Does the KMC2525E support scanning out of the box? or is a firmware update/ scan file utility needed? Help would be greatly appreciated
    Thanks in advance!
    • 23008
    Yes, the IB-23 is standard on all of the Voyager E's. Are you sure you're looking in the right place? Command Center > Basic tab > Addressbook > Single Contact....
    If you're still not getting anywhere you might try resetting the NIC with simulation U504. Or maybe the type of scanning that you're trying to do has not been enabled (FTP: U511, SMB: U512).
    I hope that helps. Can you be a little more specific?
    • Colonicaminota
      • 12
      yes, i have attached a screen shot marking where the adress book button should be.
      The scanning type i am intending to use is SMB but i was not aware you needed to enable it. Is this something you need to do in the machines engineering mode?
      cheers
      • Colonicaminota
        • 12
        i have been made aware that scanning is not installed as standard with this model copier and has been be purchased as an extra. Problem solved
        • aragul
          • Dec 2007
          • 128
          Scanning is standard on that model (in the US at least), but it's a separate network connection like the Falcon 1-2 and the KM-6030. And it's also annoying to setup like those earlier models.
          • vikingmita
            • Nov 2008
            • 163
            connected to wrong nic
            • Warstg_20
              • Sep 2009
              • 72
              Do you have a service manuals on this sir? Colonicaminota
              can i ask a copy, if ok for you
              you can send it here Warstg_20@hotmail.com
              thanks and more power
