I work with Dustin. When he finally got the firmware to update, the machine displayed "completed" on the screen. The service manual says then to turn off the power switch on the panel and then the main power, but the swithc on the panel wouldn't do anything. Did we miss something?
Dustin's KM5050 firmware update
I know I should be ashamed of myself. Strangely though, I am not. -
It might say that in the manual, but the power switch on the op panel won't do anything after a firmware update. Power off at the main switch, remove your CF or USB stick, then power On at the main switch. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
The original Mita manuals had several references to "deveroper units". I think there's already a great thread on this subject.
As loading firmware goes, the instructions are great for the actual loading, but not a word about which machines need formatted CF cards and which don't, and how the files must be prepared on the card. It was the trial & error method. Congratulations. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
