taskalfa c2810 TSB
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    taskalfa c2810 TSB
    Just reading the correction and things, with the added spring in the n00zle, I dont think the spring will greatly improve toner accumulation, might make it worst.
    AND, I think its the exist path that's the problem, the spring loaded cap will get caught up on the felt pad and thus not open, due to the felt pad saturated with toner.
    on the normal waste toner path by colour devs, the volume exiting is not as much as the waste sum, therefore those were never the problem.
    LIght users will never encounter this problem, its the heavy users that do.
    need your 2 cents, meowth!
    Idling colour developers are not healthy developers.
  • Jules Winfield
    • Jul 2009
    • 823
    Try measuring the output of the flux capacitor. Should be about 1.21 Gigawatts.
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      no.
      its 1.20723123582639345002834 gigafarads
      • taskalfaman
        • Nov 2009
        • 137
        hi,
        I placed a few springs in the past and to be honest; if you built in the spring in the right position and direction.
        the problem of C- 2810 was permanently solved in all my cases.
        I don't know why you are so suspicious?
        have fun.
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          Originally posted by taskalfaman
          hi,
          have fun.
          I just think it needed more as a remedy then just a revised spring. If it worked out great, then I had nuting to worry about.
          Cheers
          • taskalfaman
            • Nov 2009
            • 137
            all the new machines are already with spring, so nothing to worry about;
            only the older machines.
            have fun
            • hockey
              c2810 code. we had to change the motor and that fixed the issue
