After installing all new units in a Maintenance kit I ran all the sims from the manual. The Colors are finally solid but the yellow is green and the cyan is greenish. The middle of the page also gets a black streek that is bar shaped lead to edge. The transfer unit is also new. Please advise on what this can be if any one had the same problems with this machine. Thank You
KM 4035E color
Tags: black, color, color toner, consumed, cyan, installing, kit, maintenance, manual, spacers, transfer, yellow
Can you post a sample? Is it possible that the yellow and cyan toner cartridges were installed in the wrong locations? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
km c4035e
yeah that happened but after switching them back the colors wont come back even after drum and developer refresh. I Attached the image the streak in the middle was a problem in the old belt as well except it was color blocks down the middle. Thanks for all your help black cat let me know please how this can be solvedAttached FilesLast edited by yannii33; 04-19-2011, 03:45 AM.Comment
I was just kidding about the toner cartridges. The way I recovered from wrong color toner installed was to create an electronic original that is 100% yellow fill, then print off 7 sets of 10 pages. The cyan toner will be consumed out of the yellow developer.
The new problem does indeed look like a transfer belt cleaning problem. The maintenance kit includes a new assembly. Did you install it? Did you remove the foam spacers? My bet is that one of them is hung up on the transfer belt cleaning blade.
I thought only my customers had the necessary skills to insert a cyan toner cartridge into a yellow holder. Funny! =^..^=If you'd like a serious answer to your request:
Awesome thanks again ur the man I also noticed tghat the developers didnt have much DV on the as when i first installed them. I had lowered the bnias leverls by five cause of poor quality and the DVs looked solid full of color now all of the barley have any dv on them..what could that mean? I just replaced the transfer unit there was no cleaning unit??Comment
yanni,the cleaning unit is on the back of the transfer belt as you take it out of the machine,check for tapes,stoppersComment
