KM-4050 Copy problem - blank copy
  • sggarge
    • Jun 2009
    • 19
    [Misc] KM-4050 Copy problem - blank copy
    Hi everybody, Recently I cleaned Optical section of KM-4050, as lens, exposure lamp and mirror was very dusty I cleaned it with white cloth. after finishing cleaning I properly closed optical section and when i try to copy of original document blank print is coming out. As I print from computer print is coming very good but copy is blank print. Any Idea? please suggest. When I run maintainance code U411 Error coming out at INPUT Section, Error code is 04 (In service manual error 04 is showing black band is not detected (scanner leading edge registration) How to resolve this issue? Thanking in anticipation
  • Eric1968
    • 2459
    Re: KM-4050 Copy problem - blank copy
    Check the mirrors. Maybe you accidentely moved one during cleaning.
    • sggarge
      • Jun 2009
      • 19
      removed all mirror again and fixed it properly, still problem is not soved, help me if u r online, my skype is sggarge
        • 22858
        There is a shading plate there somewhere (white reference sticker) either on the underside of the index plate or the underside of the scanner's edge. The "black band" referred to is a stripe on that shading plate, that acts as a reading starting point. If the CCD cannot see this stripe, it could be that the stripe is faded or just gone, the scanner is out of position at the specific time it's looking for it, a mirror could be misaligned (it's very easy to knock loose one of those spring clips), the CCD could be out of position/focus (did you remove the CCD? or lens?), or maybe you dislodged one of the cables to the CCD or shading PWB.
        Hopefully you did not remove the CCD or lens. Those are aligned at the factory, and are very difficult to re-align without the factory tools. I spent most of a day on a Panasonic fax, in which the genius tech removed the four painted screws, then could not get an image any more.
        I'd probably start right at the shading plate, and examine each component along the path to the CCD:
        shading plate > mirror1 > scanner cables/rails/gliders > mirror2 > mirror3 > lens > CCD > wiring
        • sggarge
          • Jun 2009
          • 19
          Where is a shading plate? i didnt see any white sticker.
          neither i touch ccd, ccd cable nor its alignment so i think ccd is not the problem. I only cleaned all three mirror and exposure lamp, and I am very much sure about mirror alignment cause after cleaning i was precisely knock all spring clips.
          Doubtfully it is a shading plate..... but i did not remeber where it is... (while disassembling optical unit i did not remember any sticker)
          • sggarge
            • Jun 2009
            • 19
            dear blackcat, i am online on skype. and working on same issue since 10 hour. could u help me. my skype name is - sggarge
              • 22858
              The manual does not have a good view of it, but look here:
              • sggarge
                • Jun 2009
                • 19
                just read SM, It is mirror 2 on which white sticker is permanently adhered, In my case it is still there.
                • sggarge
                  • Jun 2009
                  • 19
                  THANK YOU BLACK CAT, THANK YOU VERY MUCH. RESOLVED......
                  hahahahahaha
                  Thank you copytechnet moderator, countless to say this site is very helpful
                    • 22858
                    Did you have the glass off, perchance? =^..^=
                    • sggarge
                      • Jun 2009
                      • 19
                      glass off? i did not get u black cat....
                        • 22858
                        Were you running the machine with the glass not installed? =^..^=
                        • habik
                          • 2014
                          I bet anything , just judging by him laughing that he had the glass 180' turned ...
                          Firmwares HERE
