You need to figure out which component is asking for replacement. If maintenance has been performed regularly, it should be the Drum, DV Unit, and Fuser unit that all need to be replaced together. You can reset the main PM Count with U251, but I'm not sure if that will clear the message. Drum count is U110, and DV count is U157, but they cannot be cleared manually.
I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
Thank you. Are you saying they have chips in them?
