I can't clear a C-6000 code on a KM-3530, I've ran 163 with no results, I've installed two new fusers with no results, also checked continuity at CN10, can't seem to figure this one out, any help would be greatly appriciated!
KM-3530 C-6000 code
Re: KM-3530 C-6000 code
not sure about that model but might there be a trouble reset procedure?jesus loves you! (everyone else thinks you're an assh*le)
street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained -
The manual says wiring, main PWB, and power supply, in that order. But you probably already knew that. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
