How do you change the welcome/splash screen to use another image such as a company logo? I know it is possible, don't remember how to do it....
Splash/Welcome Screen
Tags: None
Re: Splash/Welcome Screen
Copy the files to an USB-stick and load the files to the machine using U224. The files are :
callwin_ext_image.png 180x200pix max 1Mb
callwin_ext_mes_detail.txt
callwin_ext_mes_top.txt
opening_ext_image.png 800x400pix max 1Mb
I did this only one time during the TA250ci, and I could not find additional info. If you have the SM, U224 tells you how to do it. -
Use an application like Irfanview to format your image to 800x400 pixels, .png file format, and named exactly as Eric specified. Use simulation U224 to import the image. I think there's a bulletin somewhere ... =^..^=If you'd like a serious answer to your request:
"In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
Image must be 800x480 for the newer models (I think 800x400 was recommended for the Taskafa's) but I use the 800x480 on the Taskalfa's and the newer units and it work just fine. Image must be saved on base directory of a usb drive saved under OPENING_EXT_IMAGE.PNG it must be a saved as a .PNG file or it will not load. I use paint.net its free and easy to use. Install opening image from U224.Comment
I am new to this whole copy world. I purchased a second hand Taskalfa 250ci which still has the splash screen from the former company. I would like to change that, but I do not know what you mean by U224. I copy my files to a usb device and then?
Thank you!Comment
Putting it back to default is very easy. Just go to maint. mode and uninstall it
U224 Panel sheet extension
Description
Changes the image data and the message of the opening screen at the machine startup and the image data
and the message of the service call screen to user specified data.
Purpose
Set according to the preference of the user.
Setting
1. Write the image data or the message data to the USB memory.
2. Insert USB memory in USB memory slot of the machine.
3. Turn the main power switch on.
4. Enter the maintenance item.
5. Press the start key.
6. Select the [Install] or [UnInstall].
7. Select the item.
8. Press the start key. Installation or uninstallation is started.
9. When normally completed, [COMPLETE] is displayed.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
Maintenance
item No. Description
Display Description
Unlock Release the lock of the operation from the system menu
Partial Lock Partially lock the operation from the system menu
Lock Entirely lock the operation from the system menu
Display Description
Install Installs the image data or the message data
UnInstall Restores the original image data or message data
Display Description
Opening Img Startup screen
Call Img Service call image
Call Msg Top Service call screen 1
Call Msg Detail Service call screen 2
