Taskalfa 4550ci Hard Disk
  • daveyball
    • May 2009
    • 314
    Is there anyway to incereas the sixe of the partition of the HDD used for private print jobs. I have a customer that uses this feature all the time (every print job) there are 15 users all printing to it, and we oftern get "low memory errors"
    Thanks in advance
  • Eric1968
    • 2458
    Re: Taskalfa 4550ci Hard Disk
    This machine has 2 GB of memory and a 320 GB HDD. I can't imagine that 15 users are sending more than 320 GB of data to the machine's HDD. Maybe formatting the HDD is an option, or checking the size of the private box settings.
    • daveyball
      • May 2009
      • 314
      Where do you check the size of the private print boxes?, and are they adjustable
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        I have seen the print driver emulation cause that, try changing it
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
