Kyocera TA520i C8800
  • blackdog
    • Jun 2012
    • 211
    Boy I can go for months with no issues, and then the s@*% hits the fan.
    Anyway this box has been in the field for three years without so much as a sqeek.
    The IT guy called me and said he was getting a C8800 Finisher error.
    Off and on resets it but happens more often now.
    Service manual mentions a reg. motor?
    Has anyone had this issue and resolved it?
    Thanks gentlemen & ladies.
  • blackdog
    • Jun 2012
    • 211
    Re: Kyocera TA520i C8800
    Here's what I found.
    Did a service status report/ NO FINISHER INSTALLED!
    After correcting the issue I would guess the error code should go away.
    I'm happy I went with the obvious.
      • 22999
      So ... a U906 partial reset did the trick? When you get a finisher error it will lock out finisher functions and will not display the error. The base machine will function normally, well as normally as it can with the finisher functions blocked. =^..^=
      • blackdog
        • Jun 2012
        • 211
        No go on the U906.
        The obvious and time tested > remove finisher connector, power down, reconnect connector, power up
        run service status.....wala, finisher 3000 now connected. Why it dosn't state a DF760 I dough no?
        In the past week at this account I have had some strange issues.
        2 Canon IRC3480'S with rams cleared. Took me awhile but I finely got them back to service with the help of this forum.
        Sometimes I think IT dept is the culprit.
        I'll tell ya I can go for months without any mind blowing issues, and then the s*%& hits the fan.
        Go figure.
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          Have had a few with the same issue, reconnected finisher plug and no call backs
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
