Task Alfa 300i
  • Arc Angel
    Junior Tech
    • Jul 2012
    • 65
    Task Alfa 300i
    Hi, I was wandering if there was any other machine that has a similar fuser unit to the task alfa 300i. I mean any of the old KM machines.
    The secrete of staying young is to live honestly, eat slowly and lie about your age..... No man is so poor as to have nothing worth giving.
    • 23007
    Re: Task Alfa 300i
    The CS-2560 or KM-2560 is identical. Others, not so much. =^..^=
    • Arc Angel
      Junior Tech
      • Jul 2012
      • 65
      Re: Task Alfa 300i
      Thanks.
        • 23007
        Re: Task Alfa 300i
        Some of the other Kyocera fusers have separate parts available, but not this one. About a year into production a bulletin came out stating that the fuser was only going to be offered as an assembly. Really, it's a very simple fuser along the same lines as the FalconI, FalconII, and FalconIII. The rollers are not the same size as any of the others, and the assembly cost is quite cheap. Hardly worth attempting to rebuild. I do hold onto any fusers that reach the 300K maintenance intact. I use them to cover the situations where they don't reach the 300K.
        • Arc Angel
          Junior Tech
          • Jul 2012
          • 65
          Re: Task Alfa 300i
          I'll keep that in mind. Thanks.
