Drum & DV unit removal on CS 250ci ?
  • delosangeles
    • May 2008
    • 266
    Hello everyone We have a client with a CS 250ci that we need to replace the Drums and DV's and we mostly work on the Ricoh line. We would be grateful for any info on the removal process. Thanks in advance for any help
    Trade like a tiger sleep like a baby
    • 22743
    Re: Drum & DV unit removal on CS 250ci ?
    In this order: 1) remove fuser, 2) remove transfer belt assy (if there is an external finisher the belt assembly will just barely clear the finisher), 3) remove waste toner bottle and holder, 4) remove for toner cartridges and toner hopper assembly (full front inside the front cover, (5) screws with long magnetic screwdriver, connector cover at upper right, connector, latches at far left and far right simultaneously), 5) four developing units (1 shoulder screw and one connector each unit), 6) four drum units (one connector each), 7) vacuum out cavity, clean patch sensors: black strip visible through left door-black plastic arm at front opens sensor window, wipe any remaining with stretch-n-dust, feel free to bleed freely from your forearms, 8) Clean any primary charge rollers as needed, 9) re-install drum units to be reused, 10) Install new drum units, 11) vacuum any excess toner from developing units, check for leaking rear bearings, 12) reinstall developing units to be re-used (developing unit pins to the appropriate drum to provide proper spacing, 1 shoulder screw each), 13) install any new developing units (make sure that new developing unit turns freely, and that developer is covering the mag roller evenly front to back, tip unit to even out developer, 1 shoulder screw each), 14) Plug in four drum units, four developing units, 15) install toner hopper (fit hopper over various waste toner spouts, latch left side first, then right side with a click, 5 screws, 1 connector, connector cover with 1 screw, four toner cartridges), 16) vacuum out waste bottle holder, and install new waste bottle and holder, 17) insert transfer belt assembly (take your time on this: there is a fin at the front and back that will guide the transfer belt assembly in on tracks. It takes a few tries to get it just right. Don't force it. The transfer belt will touch the upper frame when it is inserted properly. Gently press the transfer belt tensioner down to clear the frame, and slide the rest of the way in. The belt assembly drops into a groove when it reaches the final position. Attach connector and guide wires straight down to clear the fuser. 18) install fuser, two screws (don't over tighten), 19) close doors, covers, and finisher. 20) Perform color calibration. Plan on ~2 hours with a good cleaning and calibration (and no serious problems). =^..^=
    • delosangeles
      • May 2008
      • 266
      Wow thank you very much What is the yield on the color drums? I noticed that the color drums are only sold as a set of 3 or am I mistaken. Thanks and have a great day
      • Kidaver
        Ghoulscout
        • Apr 2011
        • 912
        There are two maintenence kits....the black one which has 1 black dv, 1 black drum, transfer belt and roller, and fuser and a few other lil things....then second is 3 dvs and 3 drums for the color. each kit has it's own maint cycle
        "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
        • delosangeles
          • May 2008
          • 266
          Interesting and what are their yields? Also was wondered if the black drum could be used in the color positions without modifying or with modification to the black drum. That's what we do on the Ricoh''sThanks for the info
          • Kidaver
            Ghoulscout
            • Apr 2011
            • 912
            should be 300k on both kits. And yes drums are swappable, but there is a mylar and 2 foam pads that kyocera recomends you put on the black drum for toner dusting.
            • delosangeles
              • May 2008
              • 266
              Really, good info to have. Thank you very much On the Ricoh MP C4500's the connector on the black drum needs to be modifiyed to match the same shape as the color drums and that makes them swappable.Have a great day
                • 22743
                Yes you can swap drums. They're chipped, and yield ~300K, usually less from the color ones. I'm not sure why. You can order then separately, but the cost is considerably more for three single, than 1 set of three. As you probably already know the first time is always the hardest, so take your time. =^..^=
                • delosangeles
                  • May 2008
                  • 266
                  Yes it does look very evolved, I will search for a PDF with the illustrations to help with IDing the break down.Thank you very much for all the help and have a great day
                  • Kidaver
                    Ghoulscout
                    • Apr 2011
                    • 912
                    Also update the firmware to the latest version when you do all this. And if you did have an old style developer in the machine and put a new one in, after running some print jobs your developer will ratchet back some making a clicking noise.....inform your customer of that if this is the case and save yourself a service call or two...
                    • delosangeles
                      • May 2008
                      • 266
                      Really we did not consider the firmware updating. How is that accomplished throught IE interface to the Internet or through a SD card ? That's what we do on the Ricoh line. Your really well versed on the CopyStar line. Thank you kindly again and have great evening
                        • 22743
                        No, ... and No. On the Saturn series firmware is loaded from a 1GB USB flash drive. No extraordinary formatting required. Just extract the firmware files to the root of the stick. Nothing else on the stick. > Power machine Off > insert USB Flash Drive > Power On > it usually takes ~25 minutes to flash, but don't interrupt it, I've seen it take as much as 1 hour. > wait for the "Completed" screen. > take the time to read if each firmware piece was "Completed ", "No Change", or "Failed". This will be your only opportunity to confirm if it worked. > power Off > remove USB Flash Drive > power On. > Voila! =^..^=
                        • delosangeles
                          • May 2008
                          • 266
                          That is sheer genius! So simple, makes me want to flash machines just for kicks Thank you again kindly, you guys are great.
                          • Kidaver
                            Ghoulscout
                            • Apr 2011
                            • 912
                            yeah flashing kyocera or copystar are easy..but like he said it can take a while...thats when I pull out the iPhone and start reading an ebook....
                            • Zackuth
                              • Aug 2009
                              • 448
                              Yes, definitely upgrade firmware when replacingdevelopers. I did a 250ci without upgrading and the machine threw a developermismatch error code. It seems that the newer developers won't work on oldfirmware.
                              If at first you don't succeed, redefine success
