kyocera taskalfa 250ci makes red copies.
  • javier4065
    • Feb 2007
    • 251
    hello Friends,I cleaned the scanner unit,mirrors and len. but it still makes red copies, I think that it can be the laser unit, and my question is, how can I disassembly th.is unit to clean? waiting for your help.thanks
  • Tonerkiller
    • Oct 2012
    • 665
    Re: kyocera taskalfa 250ci makes red copies.
    Replace the M drum unit
    • kyogenius
      • Jul 2012
      • 136
      replace your main charge unit , on the magenta drum unit,i suppose the main charge z faulty on this drum unit.If you want to prove it sworp the charge units with another charge on diff unit,you will see the difference
      failure is not an option !
        • 22845
        Before you go replacing anything let's start by narrowing down the problem.
        Does it appear in scans?
        Does it appear in prints?
        Does it appear in U089 Test Patterns?
        Until you know the answers to these questions don't replace anything. =^..^=
        • JustManuals
          • Jan 2006
          • 9919
          Paul@justmanuals.com
          • javier4065
            • Feb 2007
            • 251
            Thanks, blackcat , you are right, I did adjust with tests pattern ,and I solve my problem.
              • 22845
              Don't get me wrong. I like being right, but what was I right about?
              I think I advised you not to do anything until you narrowed down the problem. =^..^=
              • javier4065
                • Feb 2007
                • 251
                I checked the copy and the print are too red ,but I was reading de user's manual and I found color adjustment and I follow the procedure. Now the copt is fine.thanks.
