Does anybody know if the cleaning blade is available for this machine? I have one with 75K on it and is leaving streaks on the drum. I hate to order a drum unit when all I need is a blade.Thanks in advance
Need a KM 3060 Cleaning blade
Re: Need a KM 3060 Cleaning blade
Dis-assembly is not such a big deal, its finding the blade that's the challenge. There's a retaining ring on the drum drive coupler that must be removed, and the coupler, and the drum ground contact on the front. The drum shaft slides out the front.
But you still don't have a blade, and AFAIK it's not available separately. You might try just cleaning the blades contact edge with a Q-tip and alcohol, then re-priming the blade. Quite often, it's just foreign matter on the blade that wipes right off.
That retaining ring can be a challenge. I've broken a couple of pairs of retaining ring pliers on this kind of clip. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
