KM-6030 banding on enlarged 154% scan of IDs
  • Ingersoll
    • Nov 2008
    • 74
    [CQ] KM-6030 banding on enlarged 154% scan of IDs
    When scanning an ID w/ 154% enlargement using auto or manual exposure the output copy has distinct line banding of certain colors (of original) in output (shades of gray). Maybe a CCD problem?
    Scan_20121213_095238_000074014dfc.pdf
  • ES-OGT
    • Aug 2011
    • 129
    Re: KM-6030 banding on enlarged 154% scan of IDs
    Have you tried something that's not an ID? I'm guessing it's got a clear coat of some sort on it that could cause problems with light distortion that's seen when it's magnified.
    Just throwing darts here. I've still got a few 6030's in the field but the customer don't do any magnification.
      • 23008
      If it's solarized, perhaps you can lay a transparency on the glass before the glossy original.
      If it's a moire' pattern perhaps a change of resolution, original type, file type, or enlargement might help.
      In either case there isn't really a "fix", more like a workaround. =^..^=
      • Ingersoll
        • Nov 2008
        • 74
        Made a copy of a mouse pad, same thing 100% good, 154% banded.
        • Ingersoll
          • Nov 2008
          • 74
          Kyocera Tech Supt 1st said "adjust the CCD" then they said "Oh. that copier doesn't have an adjustment for the CCD, guess you'll have to replace it." :-)
            • 23008
            ... If it's a moire' pattern perhaps a change of resolution, original type, file type, or enlargement might help... =^..^=
            ... and the scan settings? Any of these make a difference?
            Out of curiosity, what is so special about 154%? 155% is indistinguishable by the naked eye.
