J0501 with TA-5550ci
  • kaborwen
    • Feb 2010
    • 146
    [Jamming] J0501 with TA-5550ci
    Hi all! I have J0501 with TA-5550ci. I get it up to 220 times for 110 000 total count. After clean all pulley, it's still. I need help to fix it please. If there are services bulletin about it , I will be glad to get them. Thx all.
  • copymech
    • Sep 2011
    • 196
    The feed tires often wear out early and need frequent replacment.
    • tonerlung
      • May 2008
      • 27
      Re: J0501 with TA-5550ci
      • daveh12
        • Jul 2012
        • 157
        The Sep rollers on the pick up assemblys wear down very fast 40k approx. There are modified rollers now out, harder wearing. There are also modified springs out for the assemblys that relieves the tension slightly on the Sep rollers. This helps but it only improves life of the rollers to about 100k. Then they have to be changed.
        • kaborwen
          • Feb 2010
          • 146
          Thanks all,
          I Will replace the rollers.
          Best regard.
          • FINGERS123
            • Nov 2012
            • 33
            There is a new update to the troubleshooting guide you can find it on KDAconnect and it talks about that jam codee
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • kaborwen
                • Feb 2010
                • 146
                I do not have KDAconnect account. Can you help me with it?
                I replace the pulley so now it's seems to be ok.
