4550ci
  • scottybbb
    • Dec 2010
    • 126
    4550ci
    Any way to clean the charge rollers in these models to eliminate the lines in color copies?Or do we just need to change the roller?
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: 4550ci
    I use glass cleaner, it works well. Just remember to clean off Amy residue before you turn the charge roller to clean the next bit. Spit also works well.....
    The gene pool could use a little chlorine.
    • JustManuals
      • Jan 2006
      • 9838
      Re: 4550ci
      Paul@justmanuals.com
        • 23008
        Re: 4550ci
        Ditto that. Ammonia-free glass cleaner, and wipe completely dry. Don't overscrub the surface. If the outer skin of the charge roller rips you're screwed. =^..^=
        • Tonerkiller
          • Oct 2012
          • 668
          Re: 4550ci
          I use water to clean them. When the black layer is worn through you have to replace the roller.
          • 10871087
            • Jan 2005
            • 1062
            Re: 4550ci
            just about anything will help, I use glass cleaner a lot but I use it for everything. Won't make it new again but will help a not-too-picky customer's CQ and save you a couple bucks.
            • Venom
              Technical/IT Support
              • Nov 2009
              • 765
              Re: 4550ci
              wd40 works too, as well on drums too
              IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
