Ok... here is what I have done...
customer complained that machine was unable to print or fax... after move...
I updated firmware... no change
performed 20, 21, 906 and 163... no change
I found a working machine at shop... a km 3050... I took the dim... the hard drive and the ram... and 2 extra hard drives 80 gb each...
I switched dim... no change...
performed firmware upgrade... no change...
switched ram... no change...
performed firmware upgrade no change...
switched hard drive no change...
did the hard drive firmware thing three times... no change...
I took the machine back to the shop...
took out the engine board I believe its called... checked all connections...
pulled the engine board ( board with ethernet port) from the km 3050 put the km 5050 engine board rom ( board with ethernet port) on it...
stuck the km 3050 engine board( board with ethernet port) in the km 5050... now machine prints scans and copies... haven't checked the fax yet...
my question is there any way to unblock the original km 5050 engine board... ( board with ethernet port)
