help to use two network :( kyocera 3050ci-3051ci
  • djcan
    • Jun 2014
    • 11
    [Misc] help to use two network :( kyocera 3050ci-3051ci
    * There are two networks independent from each other in the workplace
    * I want to use the print and scan both network
    * but I can not use the scan for the second network card is not in the nature of the card into the printer by (ib-50 card that I wear on the printer KIB50.jpg)
    * Is there a different method or a different network card, please help
  • allan
    RTFM!!
    • 5462
    Re: help to use two network kyocera 3050ci-3051ci
    use scan to email?
    Check this thread
    http://www.copytechnet.com/forums/ca...oth%20networks
    Whatever
    • nmfaxman
      • 1702
      Have their IT person do some subnetting research.
      Not your problem, IT problem.
      • Kyo fan
        • Dec 2013
        • 368
        You can print and scan on your default network interface, but you can only print on the optional IB-50, since it 's not made to scan on it.
        • djcan
          • Jun 2014
          • 11
          [QUOTE = allan; 468.774] e-posta tarama kullanabilir miyim? Bu kontrol thread http://www.copytechnet.com/forums/ca...oth%20networks [/QUOTE]
          no, they just want to scan SMB
