KM3050 noisy panel fan in standby
  • copydocinc
    replied
    Re: KM3050 noisy panel fan in standby
    FYI the fan on the back of the machine, inside the print system back cover is the same fan, if you need another to try out.
  • Chillaholic
    replied
    Hey guys thanks for your answers, I will open the panel again and see if it the fan is too loose. Electrical tape sounds like a good idea, I should try this and I will look for the plastic film to be in place.
    replied
    I've had a few of those fans that fit quite loosely in the plastic duct. When the fan spun up to high speed it would vibrate in a very annoying way. I used electrical tape, and wrapped 5 or 6 wraps around the outside edges of the fan, then used some additional force to snap-fit it into the duct. =^..^=
  • kjg
    replied
    Oops. my mistake. I am guilty here of the one thing I dislike: Techs that post without reading whole text.
    I did read it but was distracted and posted quick reply.
    I sincerely apologize.
    In answer- I never had one that I replaced that was noisy after replacement. Perhaps try another fan? could be a bad one. I do remember some thin plastic film that the fan sat in perhaps to guide airflow. Could that be out of place and causing the noise?
    Just a thought.
    I hope it helps..
    If you are careful, you can keep the op panel up and turn it on to further isolate the cause.
  • Chillaholic
    replied
    Did you even read the text? I was even posting the same PN and name. I replaced it with a new one. But its still louder then it should be. Thats why I am asking if there is a way to throttle the fan down. The problem appears only in standby, because its the only fan running in standby.
  • kjg
    replied
    Just replace the fan. They go bad. P/N 302GR44010 FAN OPE
  • Chillaholic
    started a topic [Misc] KM3050 noisy panel fan in standby
    Hey techs, I got a KM3050 which is making quite loud noises from the front panel. I changed the "FAN OPE 40-10" (302GR44010) but the noise didnt change a lot. Its still loud, tho the old fan was very dusty. Do you guys have any idea how to throttle the fan down in standby?
