Re: Kyocera KM-5035 Finisher. Screen says: Attach finisher and close finisher door.
You're welcome. Glad I could help.
Zackuth,
You were spot on. Today I opened up took a look at the 2 strips and they were both bent so I straightened them out and when I reconnected the imager Voila, problem fixed. Thank you once again for you help, I greatly appreciate it.Leave a comment:
I didn't record anything on it, but I've got a vague recollection of ordering a plastic bracket/microswitch holder. The enduser had gotten quite violent slamming the finisher. =^..^=Leave a comment:
Again, thank you very much for responding. I greatly appreciate it. I will try this first thing Monday morning and I'll let you know the results.Leave a comment:
Yes, the finisher door and the switch that lets the machine know that finisher is attached. I don't remember where it's at and don't have the style of finisher here. Once you see the switches you'll know what I'm talking about.Leave a comment:
Thank you very much for replying. Are you talking about the switches on the finisher door?Leave a comment:
Guest repliedRe: Kyocera KM-5035 Finisher. Screen says: Attach finisher and close finisher door.
The switches have a metal strip used to help push the switch down and the metal will bend over time. Just straighten the metal strip and it should work fine.Leave a comment:
