TASKalfa 300ci noisy
  • kyove
    • Apr 2015
    • 62
    Hi Guys,
    I have a problem with a TASKalfa 300ci. It works fine but makes a horrible sound. No paper jams and no errors on display/event log.
    I make a video so you can hear the sound, download it here.
    Sound is produced every time a print job was finished: if I print 10 pages, i hear sound at the 10th page, not every page.
    Any ideas/suggestion?
    Sound seems to come from the drive unit upper the main power board. I already try to change motor and developer motor.
    Thank you in advance,
    Kyove
  • NeoMatrix
    Senior Tech.
    • 3514
    Re: TASKalfa 300ci noisy
    How many clicks/counts on the machine.?
    Sounds like a dry idler gear oscillating on the shaft???
    Its in the final exit assy. Try running some output motor tests in service mode.
    • Tonerkiller
      • Oct 2012
      • 665
      That is my vote also.
      • kyove
        • Apr 2015
        • 62
        MFP has 107220 B/W and 7917 Color clicks for a total amount of 115137.
        I've already tested with:
        - U030 (motors)
        - U032 (Clutches) with motor on
        - U033 (Selenoids) with motor on
        And i had no strange sound.
        I have the noise when:
        - I woke up the printer from standby
        - After the printing job (video issue).
        I think it's something in the exit section, il will make noise every page, not only at the last page.
        I want to disassemble drive unit but unfortunately Service Manual do not talk about disassembly of drive units...
        Kyove
          • 22865
          It's fairly unpleasant to dig into the main drive: 90 minutes minimum each way. I would make absolutely sure that's what you want to do, before you dig into the main drive.
          If you cannot demonstrate your noise in U030, here are a few possibilities that will not appear in U030
          -Guide B1 assembly not properly latched
          -drum waste toner backup in the hopper assembly
          -transfer waste toner backup
          I have written up a step-by-step for removing the Saturn main drive. If you would like the PDF, please send a PM with destination email. =^..^=
