Develop Ineo+ 25 - not installed toner error
  • peterdebreakeder
    • May 2015
    • 8
    Hi
    I have a Develop Ineo+ 25 that is showing the error message not installed toner check ymc
    I have tried replacing each toner individually including black
    I have tried replacing image units individually
    I have tried replacing mfpb
    During my attempts i get different erros dependant on what I replace
    for example I replaced the 3 toners above I got error cyan IU not installed.
    I replaced cyan IU, i get error cyan and magenta IU not installed and so on
    when 1 part is removed it shows the correct part being out but as soon as you put it back in it throws all errors
    any ideas?
  • copier tech
    • 8003
    Re: Develop Ineo+ 25 - not installed toner error
    Have you tried updating both the firmware files?
    • peterdebreakeder
      • May 2015
      • 8
      ah i forgot to mention
      I tried upgrading the firmware, however there seemed to be an issue with that too - now I normally work on the olivetti version of this machine and am
      assuming the firmware upgrade is the same. When i try it via connecting USB cable it says there is no device driver installed even though the machine is showing as available in the printer queue
      • copier tech
        • 8003
        I always update the firmware directly from a USB pen drive, rules out any "printer not installed" issues.
        Another point to note the C25 & C35 toners are differant (image units same) i've seen the wrong toner sent out a few times, they fit OK but differant eg one has a chip the other doesnt etc also yours is a develop model & you using KM or + toners?
        • peterdebreakeder
          • May 2015
          • 8
          how do you get this firmware on a pen drive?
          i have it as an exe file.
          i have tried all - KM, develop and olivetti toners
          • copier tech
            • 8003
            Its the same .exe file, put them both on a USB drive, from service mode choose update firmware & point to your USB pen.
