Epson T5270 servprog.exe
  • rastlin2525
    • Oct 2019
    • 2
    Looking for the service program for the Epson T5270 servprog.exe
    I have a wide format printer T5270 throwing a paper load error and got as far as I can with out the service program. can anyone help?
    Re: Epson T5270 servprog.exe
    I take it you are NOT a certified tech?
    that program is copyrighted software
    a certified tech can lose his tech ID.. his dealership WILL lose their dealership
    both could be sued
    HIRE A TECH
    This is beyond your level of expertise
    **if you Don't know what you are doing Servprog could brick your printer **
    • rastlin2525
      • Oct 2019
      • 2
      both could be sued
      HIRE A TECH
      Apparently management never followed through on getting our service department fully certified. go figure. thanks for the heads up. I didn't want to work on that machine anyway!
        they aren't that hard (unless PH replacement)
        but servprog like I said is tricky if you don't know the steps...
        sometimes on the t5xxx series IF you have the manual.. you can get some things taken care of thru the ctl pnl
        • Codex
          • May 2008
          • 694
          Memento Audere Semper
          • Codex
            Codex commented
            Editing a comment
            Re: Epson Workforce Wf-c 20590 white stripes and ink smudge
            do a complete head cleaning.. may take a few times.
            are you using genuine OEM ink?
            make sure an AC vent isn't blowing on it
            We use only original Epson ink... And there is no AC.... I'm going mad... The customer is angry.... And no help from Epson
            Inviato dal mio SM-G935F utilizzando Tapatalk
          • printsolved
            printsolved commented
            Editing a comment
            Have you tried reducing the density on the print driver?
          • NicolaiBL
            NicolaiBL commented
            Editing a comment
            Hi there.
            If you say you get no help from Epson. I guess that you are trained on the machines by Epson. They are quite tough on helping non-certified technicians.
            I would say, that mente motion unit
        • tecnodue
          • Oct 2020
          • 7
          Hallo,
          does anybody know how to fix error 100016 on WF-C5790?
          At start the machine is locked and the scanner and copy does not work, but printer is ok.
          Any idea?
          Thank you very much
          • cdvidaceiba
            cdvidaceiba commented
            Editing a comment
            Re: EPSON C5790 error 100016 on scanner
            hi i have the same problem in a 5710
            I have already reviewed those components, the machine sometimes starts without problems but after a while the error returns, the manufacturer recommends a firmware update, I already put the Japanese version and I did not succeed.
            apparently it is a fatal error of certain models with a certain serial number, is there any way to leave the machine as a printer only, even if the scanner does not work???
          • usta
            usta commented
            Editing a comment
            [QUOTE=cdvidaceiba;2109858] merhaba 5710'da da aynı sorun
            [/ALINTI YAPMAK]
            You can run the machine in technical mode and put it in print mode. It can stay in print mode unless you turn it off with the on/off button.
            In the aforementioned fault code, adf unit and main board replacement is required.
          • cdvidaceiba
            Editing a comment
            how i do that ....i know how to enter to tecnical mode but do not know how to activate that mode . can you teach me how
            thanks in advance
        • scarlethori2on
          • Feb 2022
          • 3
          Referred here from reddit.
          Purchased an ET8500 which arrived this week. Out of the box no matter the type every print comes out blue tinted. Nozzle check comes back perfectly. Colors are de-saturated and yellow is off completely.
          Attached are the following:
          - print from computer scanned back into computer - the scan looks very accurate to real life. original image on the right
          - sticker scan testing yellow. scanned and printed direct from machine with no computer involvement
          - nozzle check is here - Imgur: The magic of the Internet
          I am not looking for a calibration unit/additional cost solution. None of this is for commercial use, just home printing photos and art for the walls. Looking for a printer at this cost or less that works out of the box. If the unit is just defective or if software fixes it then awesome. If it needs extra stuff someone please point me in the direction of something better for me.
          I have downloaded all epson software, drivers, updates, everything. I have tried printing from a scan, from my phone, and from the computer. All the same results, and on both premium copy paper as well as gloss photo paper.
          thanks in advance for any and all help.
          • scarlethori2on
            scarlethori2on commented
            Editing a comment
            Re: Epson ET-8500 - Color quality terrible out of box
            Originally posted by Drivee
            If printer is new, just claim it or go directly to Epson support.
            While yes, that would get rid of this particular printer, that doesn't really help my issue. Bottom line issue being is this a feature or a bug? In the sense of, if I get another of this same unit will I be in the same position? Am I doing something wrong as the end user that is causing this that will follow me from printer to printer? Is there a better option for a hobbyist photographer and artist that the you or the community would recommend? I have to uber to UPS and back to return these printers so it doesnt cost me nothing to continue trying things that will end up the same way.
            SalesServiceGuy commented
            Editing a comment
            ... most of the discussions on CopyTechNet are between technicians who support $2,000.00+ color laser/toner based print devices under maintenance service contracts intended for office use at high print volumes.
            It appears that you have purchased a sub $1,000.00 consumer grade inkjet printer via a brand name most technicians on this forum have never worked on.
          • scarlethori2on
            Editing a comment
            Oh, ok thank you. Was referred here from a redditor.
        • hekotez
          • Jan 2007
          • 91
          Hello everyone, got 2 color label printer at the workshop and im having dificulty finding information about these machines...
          The CW-C6500Ae, the machine shows error code 004417.
          The TM-C7500 error code C9.
          Does anyone have any info on any of these errors, that can help me pinpoint the origin of them? Or a service manual that you can send/trade/sell.
          Thank in advance for any help
          • eli stark
            eli stark commented
            Editing a comment
            Re: Epson CW-C6500Ae and TM-C7500
            Hi Hekotez,
            We're having the same issue with our CW-6500Ae, did you happen to find out a solution to your error code 004417 at all?
            Thanks,
            Eli
          • mjo
            mjo commented
            Editing a comment
            Just facing this issue with CW-C6500Ae.
            TL;DR the error is related to the Label Size Measurement Sensor which is behind the printing head.
            Error says:
            Printer Error
            Turn on the printer again. See your documentation for more details.
            004417
            Checked the documentation, and the Solution column says:
            Turn off the printer. Check that there is no paper jam or foreign material near the ejection slot. Turn the printer on. If the printer error still occurs, contact qualified service personnel for advice. When contacting, tell the person the "xxxxxxx" (a 6- or 8-digit alphanumeric code)
            Printer was working fine. The other day one label got it's edge over the corner and the printing head made a couple of passes and then showed paper jam error.
            I tried to pull the label out and put it again (this happened few times over the past 14 months of use).
            Then noticed a small white plastic cylinder shaped tube on the main metallic stage (where the printing happens) and this error started showing (can't recall if it is the error first then the plastic fell, or the other way around). Also found a small black pastic piece hanging over the inside left rail (where the head moves to) and so far not sure what is this for.
            Called Epson, and they said the error is related to the Label Measurement Sensor.
            I asked about that sensor location, he said it is just behind the printing head and he was nice to send me a photo. Which looked like it had a white plastic end to it.
            I tried to reattach the small plastic piece back to is slot, I did, but the error still shows and so far no luck.
          • Wolfofwallstreet
            Wolfofwallstreet commented
            Editing a comment
            Hello, I am getting an error of 004649 when loading paper, does anyone know what this code means or if they could email me the service manual to troubleshoot this problem.
            your help is much appreciated
            mkas1996@icloud.com
        • sabbish
          • Apr 2022
          • 8
          Hello
          After loading the adjustement program, i have a message : package DLL load error [126]. I have the same error on my personal and professional computer (win 10).
          An idea ?
          thank
          • methogod
            methogod commented
            Editing a comment
            Re: EPSON CW-C6000 - Adjustement program error
            pm me.
        • Copierstud
          • Nov 2019
          • 38
          We are considering selling epson plotters just wondering if you guys have any experience with them and what your thoughts are on them. I work on kip and hp plotters but have not worked on an epson.
            Phil B. commented
            Editing a comment
            Re: Epson plotter
            what models are you looking at?
            I used to work on them.
            really big problem was the printheads clogging due to AC vent drying the printheads or not being used enough.
            they guys in CA at the training are there for you to ask Q's ... greats guys.
          • Copierstud
            Copierstud commented
            Editing a comment
            Re: Epson plotter
            Sorry for delay, The T series plotters are what were considering.
        • Qwert01
          • Aug 2022
          • 20
          Hi,
          The machine will not turn on, only the epson logo appears? There is nothing in the documentation about this?
          • pizzamano
            pizzamano commented
            Editing a comment
            Have you tried entering in service mode and update firmware?
          • Qwert01
            Qwert01 commented
            Editing a comment
            I replaced the main board, after that it works.
        • ATSBMCO
          Technical
          • Oct 2007
          • 70
          Hi,
          I've been looking at an Epson WF21000, which initially had an Error of 000501 (Cap error). This was just a difficult paper jam, which the user ignored for
          a while. The paper was saturated in ink.
          After freeing this jam, the machine started up but then stopped showing error 000481 (000481 PG PID excess load error).
          I was wondering if someone would be able to help with this problem?
          These large ink printers are a bit.....
          • printsolved
            Editing a comment
            Re: Epson wf21000 error 000481
            Originally posted by ATSBMCO
            Hi,
            Remove foreign materials near print head,check HP senesor near print head,Check the train wheel parts. Is there any damage near PG motor.Replace PG motor?
        • aAandy
          • Apr 2012
          • 370
          hello everyone
          attended this machine for banding, performed head inclination & head slant (no adjustments required), perform media feed calibration & PG adjustment, test IM sensor OK, test PF motor & calibrate OK, check PF encoder OK & check PF belt tension & i did not perform any head cleaning as the nozzle test came out fine- banding improved but not by much
          in the attachment you will see 3 items - (1) a client image with the banding, (2) a nozzle test & (3) is the printout from the 'head slant check & adjustment (PF direction, manual)
          T3200 banding.pdf
          the quality of (3) looks horrible! and yet the nozzle test looks fine - i'm assuming the poor print on (3) is what's causing the banding?
          anyone got anything further to suggest? any and all assistance will be very greatly appreciated
          thanks in advance!
          • TechCrow
            • Aug 2023
            • 2
            New to the industry and forum and I was curious to get the perspective of some techs who have worked on Epson ink pack machines in the past. My company is training me for Epson now but we do not have any other techs who have experience with them yet to ask. How do they stack up against toner machines? Anything to keep an eye out for?
            If this is in the wrong section, please let me know. Thanks!
            • chubblies
              chubblies commented
              Editing a comment
              Re: What has been your experience with new Epson ink pack machines?
              We used to work on them and they were utter shite. We had the RIPS 5790 from memory. Difficult to work on and printheads failed like no tomorrow. Terrible things, and we were glad to get shot of them.
              Uhh...good luck though
          • printsolved
            • Aug 2023
            • 10
            Re: Epson SC-T3200 banding
            Do you use high quality options on printer driver or Standard? High quality can resolve banding
