KIP 3100 large voids
  • wjurls
    • Feb 2017
    • 496
    Hello guys, I have a customer with a KIP 3100 that is getting large void areas on the second have of 30"x42" prints. I have recently rebuilt the developing unit and the problem is still there. Does anyone have any tips? I am waiting on access to the "keep it printing" forum where it appears that KIP has a bulletin regarding this very problem. Anybody happen to have info on Kip Tech K105-009 by chance?
    • 23007
    Re: KIP 3100 large voids
    I've come across huge void areas exactly like that on a 7170K, towards the trailing edge of the print. If you remove a side cover, you should be able to watch the paper through a hole in the frame. You'll see a buckle/ wrinkle start to form in the paper where the paper pulls away from the drum, getting worse the longer the paper runs. That's where you get the voids: paper not laying flat against the drum or pulling away from the drum. I know of three potential causes:
    1) drum bearings not seated properly.
    2) fuser misaligned with the paper path.
    3) fuser speed set incorrectly. Fuser speed is adjustable in at least three different ways. There is a bulletin on the 7170K ... not sure about the 3100.
    The developing issue doesn't look like that. It usually presents as heavy background in a repeating pattern, or diagonal void patterns seen in areas of heavy fill (not "rorschach" random shapes).
    • wjurls
      • Feb 2017
      • 496
      Thanks Black Cat, It appeared like buckling paper to me as well. I was able to find the TIP105-009 as well. I forgot that Konica handled KIP before they went to Kyocera.
      Lee
      • wjurls
        • Feb 2017
        • 496
        Just to follow up on this. I went through the fuser speed settings and for some reason a tech at the machines prior home had all the speeds cranked way up. I set them all back to KIP defaults and the image is perfect now.
        Thanks for the help guys.
        Lee
          • 23007
          Thanks for posting back. =^..^=
