Pin voltage testing on boards
  • Copy of a Copy
    • Feb 2019
    • 14
    [Electrical] Pin voltage testing on boards
    Does anyone have a suggestion for a multimeter lead connector type for testing male pins on a logic or system board? I have the typical leads and smaller leads but was wondering if there is a lead that is insulated and can actually insert all the way to the connector base to reduce shorting out boards and small enough to fit two leads that may be close in proximity again without frying anything.
    • 16374
    Re: Pin voltage testing on boards
    My suggestion would be to buy a logic probe.
    Klein Tools VDV500-123 Cable Tracer Probe-Pro Tracing Probe with Replaceable Non-Metallic, Conductive Tip and a Light for Use in Dark Spaces - - Amazon.com
    • ZOOTECH
      Senior member of CRS
      • 3375
      Make our own insulated lead; disassemble a female connector (with the appropriate size pins) and 2 to 3 inch’s of insulated wire, and use shrink wrap/tubing to insulate the pin. Strip the end of the wire for your connection to the meter lead.
      • anothertech
        • 1766
        If you go to Amazon and search needle tip meter leads you will find plenty.
          • 23006
          In that situation I'll take two large straight-pins, then shrink-wrap all but 3mm at both ends of the straight-pins. Press the pins into whichever electrical pins you want to read, and use clip leads to connect to the head of the pins. It works better if one of the pins is longer than the other. That way the clips are not at the same height, less likely to touch each other.
          This also works in situations where you cannot reach the terminal. The straight-pins will press through the wire insulation for a quick voltage read. =^..^=
          • Copy of a Copy
            • Feb 2019
            • 14
            All great answers, thanks for the input!
              • 37452
              I have found that staples for finishers that are not yet bent work nicely as large straight pins.
                • 16374
                Many years ago when I was taking an electronics class, we had a logic analyzer that used these type of test clips specifically designed for IC pins. I don't think you can get any better than that for IC pins.
                10x/Set 28cm Test Clip Hooks Mini Grabber Jumper Lead Probes For Logic Analyser | eBay
