Samnsung CLX-6220 Series Scan and Fax manager problem
  • Kellew85
    We've recently started using this machine in work. I had the fax forwarding (to PC), on the machine, enabled and had enabled fax recieving, in the scan and fax manager on my PC. All was working great, but then I started finding the enable fax recieving had been reset ( in scan and fax manager only, samsung machine was still set to forward faxes). I kept changing it back but a few times encountered problems. After ticking the enable box and then clicking apply, the scan and fax manager seemed to freeze and then reset, so the enable box is no longer selected. Any idea's what the problem could be? And how I could set it to permanently recieve faxes on the PC?
    OS: Windows XP
    Thanks for any help you can give.
    • 22999
    What browser? Try IE. =^..^=
