Hi All,
I'm working on an Oce TDS300 and when A1 prints are done, the top part of the image is not on the paper (as if the drum turned before the paper was fed through). Also, the image is shifted to the right also cutting of some the print on the right side.
I've measured the physical dimensions of the paper and it reads correct.
I've changed over the feed clutch and it has made no difference.
I've currently perform test 51 using SDS. I'm yet to input the values on the test sheet due to external circumstances ie power outtage.
Any one with any suggestions would be greatly appreciated. thanks in advance.
regards
Steve
regards
Steve
