Proper Outlet Voltages and Ground
  • Keychain
    • Mar 2009
    • 14
    [Electrical] Proper Outlet Voltages and Ground
    Hey All ! I have a customer with a badly grounded outlet, causing error codes.
    Of course the cust doesn't believe it because their 'old copier worked just fine'.
    Am trying to find an official chart showing what the proper voltages and grounding requirements are for modern MFPs.
    Anyone out there who can link a PDF or website?
    I had a printout from when I was trained on the Kyocera Falcon 2 in Dallas, but I cant find it.
  • mrwho
    Major Asshole!
    • 4299
    Googling for "propper earthed electrical outlet" found out this one. Although the explanation is quite good (in my non-expert opinion) I don't know if it sounds official enough for you. You could try to search it yourself and check the other hits.
    Mascan42
    Ibid
    • Hemlock
      • 432
      What kind of machine did they have and what are you installing?
      “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
      • Keychain
        • Mar 2009
        • 14
        Found it..
        Neutral to Ground .5V AC or less...
        Customers is.7 to 1.8 with a 'HOT' as high as 128V ... not good...
        Thanks all...
          • 22999
          As a reference, I've always used 120vac +/- 10% (108 to 132vac), and less than 1v neutral to ground (this is the troublesome one).
          To properly document this you need to set up a power quality analyzer, and record events for 48 hours. Here is where you'll see the really interesting stuff. =^..^=
          • davidj7
            • 1107
            its a tough one to explain , neutral to ground. Most people dosent understand that grounding is very important for electrical equipment .
            a machine is only as good as your tech : source:screwtape ; the scary one
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Although the 1.8 volts between neutral and ground is a bit out of spec, I really doubt that it's severe enough to cause errors.
              The 128 volts between neutral and hot should pose no problem.
              If the power keeps fluctuating excessively, even if it stays between acceptable highs and lows, however, you can experience all kinds of goofy issues.
              As recommended by Blackcat, a power monitor is your friend here. Put one on the line and let it run for at least 2 days (I try to let it stay for a week, if possible). The results can be eye opening.
              If you don't have one, it's well worth the investment for your shop. You can get a decent unit for just under $500.
