Oce 3165 with error code M4101
  • Doug James
    • Jan 2012
    • 935
    [Error Code] Oce 3165 with error code M4101
    Thinking it is somewhere in the scan carriage...(New account at a school that school that helps troubled youth. Crazy for taking on this dinosaur but for a good cause) Also does anyone know where to get service manuals and parts for this machine ?
  • Colour Engineer
    • Jun 2011
    • 7
    Re: Oce 3165 with error code M4101
    Only Oce can service this machine as the SST in on their laptops and not on the machine. Service manuals are all so on their laptops. Don`t know about the spare parts.
    • Jerry Hat-trick
      Not true!! From VP2090 onwards this is the case, all previous models SST or SDS as Oce call is on the machine via a service code.
      As for the code its most likely to be the scanner motor failed.
      • Doug James
        • Jan 2012
        • 935
        Yeah, When cleaning the optics, I had moved the scanner from it's home position and started the machine. Found that it has to be reset from service mode. Someone sent me the procedure to get into service mode and I fixed it.
        • Jerry Hat-trick
          Starting the copier when the scanner carriage is not at the home sensor will not cause this code, it will initialise and find the home position.
          It is more likely an intermittant failure of the scanner motor and the error will probably return and you will need to keep re-setting it via sds.
          • seniortech
            • Dec 2007
            • 180
            You will eventually have to replace the scanning motor Oce part no is 2967604
            • Doug James
              • Jan 2012
              • 935
              THANKYOU !!! Sure helps...
