Oki C9500 problem of colors
  • gauthier
    • Jul 2025
    My Oki C9500 has a big problem of colors superposition. There are about 0.15 inches between each colors (ex. a green line becomes a Cyan line near a yellow line to 0.15 inches one of the other).
    The printer was blocked, asking me to change the transfert belt, so I reseted the counter (using diagnostic mode>Engine level 4>counter set). This process has unblocked the printer but the problem of color offset appeared. I changed the transfert belt but the problem continue.
    - May be that I changed others parameters by mistake? How to adjust offset colors?
    - Is there an other problem clutch, motor?... (It also tends to do a lot of paper jam)
    Thank you for your lights!
  • HELIO240
    • Jan 2011
    • 137
    Re: Oki C9500 problem of colors
    Dam'[ATTACH=CONFIG]15738[/ATTACH]
    hi, there are another mode of the adjust the register of color .
    • gauthier
      Thank you Hellio for your idea, but this setting can not absorb so much difference.
      • JustManuals
        • Jan 2006
        • 9838
        http://www.justmanuals.com
        Paul@justmanuals.com
        • HELIO240
          • Jan 2011
          • 137
          Do you have a manual for this model?If you wish I can send to you.
            • 23008
            I know this is a crazy idea, but how about just replacing the worn out transfer belt, rather than fiddling with it for many labor hours?
            Who is saving money when you spent 2 hours try to temporarily delay doing a 10 minute job?
            • gauthier
              I have the SM and this problem is not exposed precisly.
              Of course, I changed the transfert, belt but the problem continues... Damned !
              • OkiDataSupportTeam
                [QUOTE=gauthier;289013]My Oki C9500 has a big problem of colors superposition. There are about 0.15 inches between each colors (ex. a green line becomes a Cyan line near a yellow line to 0.15 inches one of the other).
                Dam'offset.jpg[/QUOTE: Gauthier, Sorry to hear about your problem. I'm from the OkiData North American Support Team and we'd like to help you. From what you've said we think it might be a defective drum, but we're not exactly sure so we'd like to talk to you. Please give us a call (800-654-3282) at your convenience and we'll get to the bottom of this with you. We're here 7x24 so try us any time. We'll also want samples so we can be sure we understand the problem. ]
                • gauthier
                  Pleased to read you, sorry but I can't call you, I'm in France. But I think too it might be the drums: each ID unit color has about 35000 images ! Besides the problem of color registration the sheets of paper are crumpled and the grey not regular. Is it the symptom of death drum ?
                  I want to be sure before changing the ID unit, the cost of 4 drums is about 1/3 of the price of the new C841...
                  Thank you for your interest in my problem, ' would like to have here a support team like you!
                  • Eric1968
                    • 2458
                    [ATTACH=CONFIG]15812[/ATTACH]
                    Make sure the ID-sensors are clean. This could also be a defective black drum. Black is the reference for CMY. Had this a few weeks ago with an C9850. CMY were way off and replacing the belt didn't solve it. Replacing the black drum solved it.
                      [QUOTE=gauthier;290340]Pleased to read you, sorry but I can't call you, I'm in France. But I think too it might be the drums: each ID unit color has about 35000 images ! Besides the problem of color registration the sheets of paper are crumpled and the grey not regular. Is it the symptom of death drum ?
                      color tuning.jpg[/QUOTE: Gauthier, here is another alternative. I can ask my counterpart that handles Oki Support for Europe to have someone from his team contact you directly. All I need is your email or phone number and I would be glad to make the connection for you. Please let me know how I can help.]
